Arcan ®   24-Apr-2017 07:44
Marine Online - Ballast Water Management Methods
Year: 2016
Genre: Learning Video
Playtime: 11:22
Quality: CamRip
Format: MP4
Video: 640x360 / 192 kbps / 16:9
Audio: 96 kbps / 44.1 KHz
Description: Ballast water treatment techniques to eliminating invasive aquatic species, reducing corrosion and complying with IMO ballast water guidelines. Ballast Water Management System for ships. Ocean-going ships take on ballast water to maintain stability when sailing without cargoes. This system ensures that ballast water is harmless when it is discharged into the sea at the loading port. Animal and plant plankton, bacteria, and other harmful materials in the ballast water are removed by the combined use of a high-performance filter, chemicals and venture tubes. This Section will provide you with information about various techniques for treating ballast water.
Ballasting.
Ballast water exchange at sea.
Sequential method.
Flow-through method.
Ballast System.
Precautions to be taken when exchanging ballast at sea .
Non-release of blast water.
Discharge to shore facility .
Sediment removal.
Ballast Techniques.
Contingency procedures.
Tang-ency procedures.
Other not yet approved techniques.
Mechanical treatment methods such as filtration separation.
Physical treatment.
Ballast Methods.
Chemical treatment.
Ballast water sampling.
Location of sampling points.
Download [15 KB]
Ballast water treatment systems: design, regulations, and selection under the choice varying priorit...
Technical Manual for BWMS AQ-0300-UV - Wartsila Water Systems Ltd [2016, PDF]
Ballast Water Management [2016, MPEG]
IMO Ballast Water Management Convention: The Solution to a Cross-Sectoral Challenge - Jose Matheicka...
Guidelines for the Control and Management of Ship’s Biofouling to minimize the transfer of Invasive ...
Guidelines for the Control and Management of Ships’ Biofouling - IMO [2023, PDF]
Guidelines for the control and management of ships’ ballast water to minimize the transfer of harmfu...
Guidelines for Application of Ballast Water Treatment Systems on Ships - Machinery Team, Korean Regi...
Marine Online - Principle ARPA System [2016, MP4]
Guide for Control and Management of Ship’s Ballast Water - IMO [1998, PDF]
The time now is: Today 03:10
