ArtGal27 ®   26-Mar-2014 18:58
RYA Complete Course
Year: 2003
Version: 2.1
Developer: Longbow Sail Training
Platform: Windows XP, 7, 8. 32, 64 bit
Compatibility with Windows7: yes
System Requirements: Минимальные.
Description:
Welcome to Longbow Sail Training
Home of The Complete Course
The Complete Course is the original, best selling PC course which covers all RYA® theory course from Start Yachting to Yachtmaster® Offshore. Start Yachting and Competent Crew are practical courses run afloat and The Complete Course gives a sound introduction to what to expect when afloat. The Complete Course is just that
Start Yachting
Essential Navigation and Seamanship
Competent Crew
Day Skipper
Coastal Skipper / Yachtmaster Offshore
The Complete Course Series can be used for either motor or sail
NO TIME FOR NIGHT SCHOOL?
DISTANCE LEARNING AND OTHER COURSES TOO EXPENSIVE?
NEED ANOTHER APPROACH TO THE SUBJECT?
Learn with The Complete Course Series at home in your own time. Many satisfied students have used The Complete Course to understand the theory and then taken a practical course to consolidate knowledge and gain the coveted RYA certificates. Use the course on its own or to back other classes. With its new easy to use "Contents" it also becomes an ideal revision and reference work. Now it is even easier to use as a reference work with an Index for each book in the courses allowing a search by word to be made. Optimized for both 32 and 64 bit PCs.
As students have said: - Its All You Need
RYA Complete Course
Download [20 KB]
Ultra Noob   16-Oct-2016 18:16
When installing it comes up with an error, when ignoring the error the install will display as succesfull but once going and try to open the program the .exe file is missing.
Ultra Noob   16-Oct-2016 18:35
SOLLUTION:
I ran it on win7 put it in compatibility mode for XP SP2, left the installation directory as the original indicated one (Initially I changed it and probably caused the issue) I also made sure none of the option where selected (adding shortcut etc).
Once reinstalled like this it installed succesfully Мигает
Упражнения по навигации от РИА - Крис Слэйд / RYA Navigation Exercises - Chris Slade [2008, DjVu]
The Complete Ocean Skipper: Deep-Water Voyaging, Navigation, and Yacht Managment - Cunliffe Tom…
The Complete Ocean Skipper: Deep Water Voyaging, Navigation and Yacht Management - Tom Cunliffe…
RYA Manual of Seamanship - Cunliffe T. [2007, PDF]
Навигация / RYA navigation handbook - Tim Bartlett [2005, PDF]
Yacht Hand, Competent Crew and Yacht Skipper - Jaaback H. [2000, PDF]
RYA Navigation Handbook and RYA Navigation Exercises - Chris Slade, Tim Bartlett [2008, PDF]
The Complete Yachtmaster - Tom Cunliffe [2008, PDF]
The Skipper’s Pocketbook: A pocket database for the busy skipper - Sara Hopkinson, Basil Mosenthal…
Sail for a Living - Sue Pelling [2011, PDF]
The time now is: Today 15:08
