zxc ®   21-Aug-2016 15:34
Wartsila SW38 Maintenance
Year: 199X
Country: Finland
Genre: Educational
Playtime: 2:09:13
Translation: N/A
Director: Wärtsilä
Quality: VHSRip
Format: AVI/VOB/PDF
Video codec: XviD
Audio codec: MPEG Audio
Description: Lightest and most compact heavy duty engine, also used for generating set applications
The Wärtsilä 38 was developed in response to a need in the market for an engine in the 400 mm cylinder bore class. The high level of technology incorporated in this engine, together with its design, and the power plant built around it, are all focused on achieving the lowest possible kWh production cost.
The Wärtsilä 38 has fewer parts, less maintenance requirements, low fuel consumption, reduced emission levels, and has the ability to run reliably on a variety of fuels.
The Wärtsilä 38 engine is fully compliant with the IMO Tier II exhaust emissions regulations set out in Annex VI of the MARPOL 73/78 convention.
01-Removal of Cylinder Head
02-Removal of Piston and Connecting Rod
03-Disassembly of Crank pin Bearing
04-Removal of Cylinder Liner
05-Disassembly of The Main Bearing
06-Assembly of The Main Bearing
07-Assembly of Cylinder Liner
08-Assembly of The Crank Pin Bearing
09-Assembly of Piston and Connecting Rod
10-Assembly of Cylinder Head
11-Removal of A Camshaft Section
12-Replacement of A Camshaft Section
MediaInfo
Video
Format : MPEG-4 Visual
Format profile : Simple@L3
Format settings, BVOP : 1
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Custom
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 1 h 1 min
Bit rate : 977 kb/s
Width : 704 pixels
Height : 528 pixels
Display aspect ratio : 4:3
Frame rate : 25.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.105
Stream size : 432 MiB (87%)
Writing library : XviD 0.0.09 (UTC 2003-03-25)
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Mode : Joint stereo
Codec ID : 55
Codec ID/Hint : MP3
Bit rate mode : Variable
Bit rate : 136 kb/s
Nominal bit rate : 128 kb/s
Channel(s) : 2 channels
Sampling rate : 48.0 kHz
Delay relative to video : 24 ms
Stream size : 60.3 MiB (12%)
Alignment : Split accross interleaves
Interleave, duration : 24 ms (0.60 video frame)
Interleave, preload duration : 435 ms
Writing library : LAME3.90.
Encoding settings : -m j -V 4 -q 2 -lowpass 17.6 --abr 128
Language : English
Wartsila W38  SILVER RELEASE!
Download [27 KB]
Wartsila 38L (dismantling|assembling) [MPG]
Процессы в дизельном двигателе - Wartsila / Diesel process - Wartsila [MP4]
Wärtsilä RTA96C-B Engine Documentation [2003, PDF]
Wärtsilä RT-FLEX96C Engine Documentation [2004, PDF]
Wärtsilä-Sulzer RT-flex60C Engine Documentation [2005, PDF]
GEM / NYK RT-Flex Basic Training - Wartsila Land and Sea Academy, Winterthur, Switzerland [2007, PDF...
Wartsila 46L Main overhaul (4 Stroke engine) Assembling / Disassembling [WMV]
Ship Power Systems - Wartsila [2006, PDF]
Ship Power Systems - Wartsila [2007, PDF]
Ship Power Systems 2005 - Wartsila [2005, PDF]
The time now is: Today 22:17
