Dimi4 ®   24-Sep-2012 09:52
Daihatsu-6DK28_operating manual
Описание: образ диска с мануалом для Daihatsu-6DK28
Daihatsu-6DK28_operating manual.iso
Download [13 KB]
Guest   28-Dec-2013 00:15
необходима инструкция Daihatsu-6DK28
tody_yanh   16-Oct-2014 10:49
is there a yanmar manual in your hand
mero55   04-Dec-2015 17:43
8166is there a yanmar manual in your hand
which model you asking for?
shcherbakov   04-Dec-2015 18:33
5284необходима инструкция Daihatsu-6DK28
5285а тут разве нет?
возможно "инструкция" для кого-то мануал, а для кого-то каталог запчастей или ещё что-нибудь.
(вышеописанное подразумевает что гость понял как качать)
AHAD MARINE   19-Jan-2016 12:21
DEAR SIR.
WE CAN SUPPLY THE ALL spares
We Supply entine spare parts in Main Engine, Diesel Generator Set, Turbo-Chargers, Air Compressor, Air Condition Unit, Fresh Water Generator, Hydraulic Pump/Motor, Lub Oil Purifier, Sea Water Pump, Heat Exchanger, Navigational Equipment, Life Saving Equipment and Electric Equipment as well. We have a huge stock of Cylinder Cover, Cyl. Liner, Piston Crown, Piston Skirt, Piston Rod, Fuel Pump, Piston Ring, Nozzle with needle, Main Bearings, Con. Rod. Bearings Thrust Bearing, Crosshead Bearing,Tie Rod Etc. of various make and types of Main engine & D.G. Sets Like Sulzer, PIelstick, Mitsubishi, Mak, Nohab Polar, Blackstone, MAN, B & W, Wartsilla, Yanmar, Daihatsu, Bergen, Crepelle, SKL. We have also got complete units of Diesel Generator set of various make and type ex-our ware house in very good condition. We have also got std. size Crankshaft, Cam-shaft, Reverse driven Gear, Governor, Engine Block.
U contact at @ [email protected]
-1
Mikabar   24-Sep-2021 21:20
Добрый день. Еду на судно - по данным там Движки Daihatsu 6DL-24, 4stroke, 6 cyl, 240x320, 883kW.
Случайно мануала на такую модель не найдётся у вас?
Заранее благодарен
DAIHATSU
Daihatsu PS-26_Operating & Maintenance Manual [2014, PDF]
Daihatsu 3DK-20 Instruction Manual - Daihatsu [1999, PDF]
Daihatsu 5-6DK-26 Instruction Manual - Daihatsu [2006, PDF]
Daihatsu DL20 Instruction Manual - Daihatsu [2010, PDF]
DAIHATSU 6-8DK-28 instruction manual - DAIHATSU [2000, PDF]
Framo Training System CBT [2012]
PMI System v. 2.3 CD Software and manuals [ISO, ENG]
Daihatsu
Regs4Ships Digital Maritime Regulations [2014, ISO]
The time now is: Today 02:02
