jawming24   12-Jan-2026 17:04
Ichoff, Hello and good day! I'd like to ask if you have a new link? Since the provided link is currently inaccessible. Thank you in advance.
memex1   19-Feb-2026 04:39
Ichoff, it says system couldnt foind VCRUNTIME140.dll try to reinstall it
borice30   27-May-2026 22:32
14qjrv080190, I inspected the assembly of the simulator.exe (i actually use ghidra) i successfully cracked the simulator.exe but, it seems to have some problems with the NFCLIB.dll, i searched into it and i found some auto-checks (Check, CheckOutFeatureNow, CheckOutModelNow, CheckOutNeptuneNow) i tried to crack it but, at least the crack works, libraries wont load... i dont understand why but it seems to have problems with "simmgr" notably with a module named "unitscheduler". i think there is some "check" or verifications on control.exe and others in simulator.exe but i actually didnt succeed to locate them and patch them... i will keep you informated but the work is advancing ! maybe i failed with some RET of JMP... sorry for my bad english
9
yesman85   19-Oct-2026 09:00
I used "reverse engineer anything" and ChatGPT 6.1 Astra to crack the executable and so far it's worked.
Two locations within that file were changed:
0x3360 Replaced a 16-byte span at the local-license validation function entry with a success return and its expected integrity-state update.
0xDD6F8 Cleared the obsolete 2-byte relocation entry for the replaced instructions, preventing ASLR from corrupting them.
17 bytes differ overall across those two spans.
Instead of linking the patched executable I attached a script that can apply the patch for you using Powershell, run as Administrator.
I uploaded 2 patches, 1 for just the .exe file and 1 to also patch some missing reg keys to get the CCTV working.
Attachments patch.zip (6 KB, Downloaded: 11 times)
Patch for .exe and missing registry keys
Attachments patch.zip (2 KB, Downloaded: 11 times)
yesman85   Today 05:13
Download the patch.zip file, extract the zip file, to your downloads folder is fine.
Then open Powershell as administrator (start -> search for powershell, right click then "run as Administrator").
Browse to the folder you extracted the zip file to by doing:
cd C:\Users\youruser\Downloads
(for exampe).
Then execute the patch by running
.\patch.p1
The time now is: Today 09:30
