TerryCG   17-Mar-2026 12:11
112763https://disk.yandex.ru/d/O1pvHkcYNTXnmA
Transas Navi-Sailor 4000 ECDIS installation set. Full license and charts are in Private Section with Virtual box. Virtual box is Windows 10 x64 with installed program and charts. Checked!
is there any guide for instalation? i got notification LS0002 This program required dongle to run if you have printer attached through the dongle, make sure the printer is switched on... how to fix this ?
Cazino   17-Mar-2026 19:02
112801is there any guide for instalation? i got notification LS0002 This program required dongle to run if you have printer attached through the dongle, make sure the printer is switched on... how to fix this ?
You did not install the dongle. 1. Install driver setinel than use video https://disk.yandex.ru/i/RVS6F3YW8Z4ztQ
clownfish ®   25-Mar-2026 20:48
I've been trying to install it on Windows 10, but it keeps showing an error message about something related to (i server) and then crashes
The time now is: Today 21:59
