twicer ®   14-Jan-2024 11:56
Guide for Building and Classing Liftboats
Year: 2024
Author: ABS
Edition: January, 2024
Pages count: 675
Description: This Guide was developed for the Classification of Liftboats and specifies the requirements for design,construction and survey after construction of the Liftboat (including hull structure, equipment andmachinery systems) for use by designers, builders, owners and operators in the offshore industry.
ABS Guide for Building and Classing Liftboats 2024.pdf
Download [15 KB]
Guide for Building and Classing Liftboats - ABS [2023, PDF]
Guide for Building and Classing Liftboats - ABS [2021, PDF]
Guide for Building and Classing Liftboats - ABS [2022, PDF]
Rules for buliding and classing Floating Production Installations (FPIs) - ABS [2020, PDF]
Requirements for Building and Classing Floating Offshore Liquefied Gas Terminals - ABS [2024, PDF]
Guide for Fire-Fighting Systems for Cargo Areas of Container Carriers - ABS [2021, PDF]
Requirements for Building and Classing Offshore Spaceports - ABS [2023, PDF]
Guide for Vessels Operating In Low Temperature Environments - ABS [2024, PDF]
Requirements for Application of Higher-Strength Hull Structural Thick Steel Plates in Container Carr...
The time now is: Today 14:29
