janataly ®   21-Dec-2012 13:50
Monday, 3rd December 2012 the revised Marpol Annex V is due to enter into force on 01 January 2013.
The International Maritime Organization (IMO) Marine Environmental Protection Committee (MEPC) issued a revised Annex V to the International Convention for the Prevention of Pollution from Ships (MARPOL) under Resolution MEPC.201(62). A copy of the Resolution can be read here.
The revision reverses the historical presumption that garbage may be discharged into the sea based on the nature of the garbage and defined distances from shore and now prohibits the discharge of all types of garbage into the sea unless explicitly permitted in regulations 3, 4, 5 and 6 of the Annex. Regulation 7 allows for limited exceptions to these regulations to cover emergencies or non-routine situations.
The new regulations generally restrict discharge overboard to food wastes, identified cargo residues which are not covered by other Annexes to the Convention, animal carcasses, identified cleaning agents and additives and cargo residues entrained in hold washwater which are not harmful to the marine environment. Where possible, it is recommended that all garbage is discharged to appropriate port reception facilities.
In order to assist with the implementation of and to ensure compliance with the revised MARPOL Annex V requirements, the Marine Environmental Protection Committee have issued Resolution MEPC.219(63) - 2012 Guidelines for the Implementation of MARPOL Annex V, a copy of which can be read here.
Attachments MARPOL Annex V MEPC.201(62).pdf (113 KB, Downloaded: 3070 times)
Guidance on Waste Management for Tankers [INTERTANKO] - INTERTANKO [2017, PDF]
Guidelines For The Implementation Of Marpol ANNEX V - IMO [2017, PDF]
Guide for Implementation of MARPOL Annex V - IMO [2012, PDF]
Resolutions: MEPC.314(74); MEPC.316(74); MEPC.317(74) – MARPOL amendments - IMO MEPC [2019, PDF]
MARPOL Consolidated Edition (Readable and less size 18mb) - IMO [2017, PDF]
Crude Oil Washing Systems - IMO [2000, PDF]
STS Transfer Operations Plan For compliance with MARPOL Annex I, Chapter 8, Revision 3 - ABS [201x,…
2019 Guidelines for Port State Control under MARPOL Annex VI Chapter 3 (Resolution MEPC.321 (74)) -…
Guidance to Shipping Companies and Crews on Preparing for Compliance with the 2020 ‘Global Sulphur…
MARPOL 73/78 Practical Guide - TOCPRO [2015, PDF]
The time now is: Today 14:29
