Arcan ®   13-Dec-2016 16:01
Navi-Sailor 4000 ECS v 1.11.005 [2008] VirtualBox Workstation with Win XP(En) x86 + TX97/WF 43
Year: 2009
Version: 1.11.005
Developer: Transas
Platform: Windows all x86, x64
Windows7 compatibility: no
System Requirements: VirtualBox installed, RAM for virtual engine at least 1.0 Gb and 10 Gb space on hard disk
Crack: Not needed
Description: VirtualBox Workstation with installed Transas Navi-Sailor 4000 and Win XP (En). Installed charts WF43 (Update until Dec, 30, 2009.)
Engine configured to backup.
VirtualBox works with Windows 7, 8, 10 either x86 , or x64, and also with Linux.
Additional info: 1. Install VirtualBox with VirtualBox Extension Pack
2. Create Virtual engine (Win XP x86) with RAM at least 1.0 Gb, and VideoMemory 32 mb
3. Use downloaded file as hard disk.
Download [16 KB]
Arcan ®   20-Dec-2016 09:10
27393It is not working
Did you start emu before starting Navisailor?
khanohg   21-Dec-2016 20:20
yes
27397
I have
Arcan ®   25-Dec-2016 12:49
27512Why does it have to be win xp? ANd running it on virtual box will slow it down
Running on virtual engine - is only way to run it on x64 systems at this moment. And Virtual engine with preinstalled Windows 10
or Windows 7 will cut off from host PC much more resourses than Windows XP.
If you would like to install on host engine - go ahead! All nesessary distributives and tools are exist on this tracker.
aldrin226   28-Jan-2017 03:25
@arcan hey man, is it possible to extract .vdi image without using virtualbox? for some reason, virtualbox does not recognize the .vdi file that i downloaded. says its corrupted even if i downloaded it multiple times already
Arcan ®   28-Jan-2017 08:16
28277@arcan hey man, is it possible to extract .vdi image without using virtualbox? for some reason, virtualbox does not recognize the .vdi file that i downloaded. says its corrupted even if i downloaded it multiple times already
1. Do you believe that all 80 downloaders at this moment have the same problem with vdi file?
2. Are you sure that all "extracted" program from your Hard Disk will work on another HD?
3. For your info: .VDI files are native Virtualbox format for virtual HD. Let you try to find reason in your PC. First - correctly remove and reinstall Virtualbox. Probably remove viruses which corrupt your files.
nish696   05-Feb-2017 15:46
I've followed the precedure as said, but when then navi sailor screen starts to load it gives an error message and the program gets closed automatically.
Please help.
PS: After Selecting EMU nothing is happening, is that ok or something supposed to open?
Arcan ®   05-Feb-2017 17:47
28494I've followed the precedure as said, but when then navi sailor screen starts to load it gives an error message and the program gets closed automatically.
Please help.
What you are talking about? Which procedure you are following?
Executing of EMU will not shows any messages until it NOT STARTED.
medvedevkgd   19-Jan-2018 17:21
Установил, при запуске пишет, sailor.exe has encountered the problem, закрывается.
Как решить?
Arcan ®   19-Jan-2018 17:47
medvedevkgd, Вы о чем говорите то ? О виртуальной машине или о программе установленной на вашем компе?
medvedevkgd   19-Jan-2018 19:00
Arcan, Виртуальную машину поставил, создал Windows XP 32 bit. Загружаю через Virtual Box Образ, Emu запускаю. Потом запускаю саму программу уже и выдает ошибку, Ram поставил более 1 gb
Arcan ®   19-Jan-2018 19:16
Проверьте - у образа случайно не стоит read only. Если стоит - снимите
Arcan ®   19-Jan-2018 19:20
и еще - а вы VM VirtualBox Extension Pack установили в своей гостевой Windows XP?
medvedevkgd   19-Jan-2018 19:56
37786Проверьте - у образа случайно не стоит read only. Если стоит - снимите
37787и еще - а вы VM VirtualBox Extension Pack установили в своей гостевой Windows XP?
Read only не стоит.
VirtualBox поставил на Windows 7 64 bit.
Arcan ®   19-Jan-2018 20:13
Вы не ответили - VM VirtualBox Extension Pack стоит на гостевой Windows XP ?
Chart Planner v.3 [2016]
Образ Windows 98 c Navi Trainer v.2000 - Transas [2000]
Wartsila (Transas) World Folio, Issue WF 90SE, Main & Auxiliary Collection DVD - Wartsila [2020]
HMC ECDIS v.5.1 [2014]
DNV Software Sesam Marine 2013 v.14 (sept 2019) - DNV [2019]
Digital Course Recorder Data Analysis Software - Tokyo Keiki Inc. [2017]
Xinutop: Dedicated Marine OS v.VDI version X86 2.3 - Frank Baudet [2019]
ECDIS Video Guides Part III [2015]
The time now is: Today 21:05
