pikabu   01-Jun-2019 14:48
А где можно взять эти 7 файлов? тема с ними уже удалена по-видимому
alsoin   22-Jul-2019 19:03
Перестал прописывать глубины модуль pbg. Что могло случиться? Над иконкой корабля висит 0м 0.0грд. Виджет глубины работает, глубину показывает.
onlinespiderman ®   19-Aug-2019 08:18
- Sometimes, after installation is complete,…….when you execute Maxsea in Windows 10 x64 OS,…….
the program might freeze just after it has passed the Maxsea “LOGO”,……it might not load properly,…..or it might give you a black screen.
All these issues are a result of incompatibility of Maxsea with “NVIDIA Graphics Cards drivers” when installed on Windows 10 x64 OS.
- When the installation of Maxsea applies on a pc with Windows 7 x64 OS ,……”Nvidia Graphics cards drivers” problems do not exist.
There are 2 options to solve this problem on windows 10:
OPTION A. Just go to your "Device Manager" and under "Display adapters",…. disable your Nvidia Graphics adapter.
After that Maxsea will load properly on Windows 10 OS with out freezing or getting stuck.
OPTION B. Update the driver of your graphics card to "Microsoft Basic Display Adapter”.
kuk0_0   12-Sep-2019 01:20
Hello,
How can I change the port COM? Now it is 6 and it shows me that there is not nav data. I want to receive an information from COM 12.
How to adjust the display wide? Its on half of my screen.
dm210f   17-Dec-2019 23:05
Hello mates. I faced the problem on the step №7. When i start CMapRTe.msi is is asking to insert the CD. What the problem can be and if there any solutions, please reply asap. Thank you!
cprhscy   11-Feb-2020 10:54
Доброго времени.
Установка программы прошла без проблем.Все степы пройдены.
Но при запуске программы она висит в процессах и больше ничего не происходит.
Кто сталкивался с такой проблемой?
Windows 7/64.
ozcan0715   18-Feb-2020 21:21
at first thank you for nice sharing. i followed the instructions. the program installed ad activated ,so far everythig is good. but after i execute maxsea,when i want to open charts,its freezing. i believe i made a mistake when i install but i cant find where is the mistake. do you have any idea what may cause this? and any advice for the solution?
The time now is: Today 20:48
