zuburki   10-May-2021 12:53
Thom,
Open note pad:
Paste this:
@echo off
rem mickael le 14/11/16
TITLE Create files to avoid "Crack" splashscreen after installed MX TZ v4
color 1F
echo MaxSea TIMEZERO V4 PRO
echo.
echo This SW app will delete the conflicting files and create 5 empty directories into your windows system.
echo Also, it will delete firewall rules pushed by MX installation.
echo.
echo concerns the paths:
echo.
echo C:\Users\%USERNAME%\AppData\Local\Temp\
echo C:\Users\%USERNAME%\AppData\Roaming\Temp\
echo C:\Users\%USERNAME%\Documents\Temp\
echo C:\ProgramData\CrypKey\
echo C:\ProgramData\Temp\
echo C:\ProgramData\TimeZero\MetaCatalog
echo.
pause
echo o|del /s C:\Users\%USERNAME%\AppData\Local\Temp\{5e3e96c-e325-11ce-bfc1-08002be10319}
echo o|del /s C:\Users\%USERNAME%\AppData\Roaming\Temp\{6f3e96c64-64f325-12ce-bhc1-08102bf10318}
echo o|del /s C:\Users\%USERNAME%\Documents\Temp\{aaa3e21c64-63sdf25-1654e-zg1-0856410318}
echo o|del /s C:\ProgramData\CrypKey\{4d36e96c-e325-11ce-bfc1-08002be10319}
echo o|del /s C:\ProgramData\Temp\{8f3e21c64-63f325-12ce-z5g1-081999f10318}
echo o|del /s C:\ProgramData\TimeZero\MetaCatalog\{aaa3e21c64-63sdf25-1654e-zg1-0856410318}
netsh advfirewall firewall delete rule name="TimeZero"
netsh advfirewall firewall delete rule name="TimeZero Navigator"
set path1=C:\Users\%USERNAME%\AppData\Local\Temp\
set path2=C:\Users\%USERNAME%\Documents\Temp\
set path3=C:\ProgramData\CrypKey\
set path4=C:\Users\%USERNAME%\AppData\Roaming\Temp\
set path5=C:\ProgramData\Temp\
set path6=C:\ProgramData\TimeZero\MetaCatalog
cd %path1%
mkdir {4d36e96c-e325-11ce-bfc1-08002be10319}
mkdir -p {5e3e96c-e325-11ce-bfc1-08002be10319}
mkdir -p {6f3e96c64-64f325-12ce-bhc1-08102bf10318}
mkdir -p {8f3e21c64-63f325-12ce-z5g1-081999f10318}
mkdir -p {aaa3e21c64-63sdf25-1654e-zg1-0856410318}
cd %path2%
mkdir -p {4d36e96c-e325-11ce-bfc1-08002be10319}
cd %path3%
cd %path4%
cd %path5%
cd %path6%
echo.
exit
And then save the file as .bat and run it
Thom   10-May-2021 13:05
zuburki, thank you for the fast respond!
I already tried that but unfortunately it still shows the crack screen.
Thom   10-May-2021 13:29
zuburki, I manually deleted/created the directory's, the splash screen is now gone!
So i think the problem was at my side.
Thanks a lot, it works like a charm now!
1652   12-May-2021 01:52
Good Days,
i need UC code for these :
SDVJAFM210MAP18.dbv
SDVJINM201MAP18.dbv
SDVJAFM209MAP18.dbv
SDVJEMM076MAP21.dbv
SDVJEMM112MAP22.dbv
zuburki   12-May-2021 02:04
1652,
6181A495A63E9AAA188E
F592F6239C16BA45180C
68443D85A73F387D183D
EC3FCA2A952FF8492192
8FF17F1834AF618F22CC
Guest   16-May-2021 10:13
Hello i need help with this uc codes: TZ Pro v3
SDVJEWM227map21.dbv
SDVJEWM228map20.dbv
Infinitesimality   27-May-2021 09:12
I could really use a UC code or Map Key for SDVJNAM044MAP07.dbv in Timezero 1.9
or a map key for any version of the chart, up to:
SDVJNAM044MAP13.dbv
The time now is: Today 01:45
