onlinespiderman ®   10-Nov-2018 21:51
46789onlinespiderman, GPS can not be connected, while trying adding it in the menu ---config--- navigation devices.
There are no COM ports available to add the GPS.
Any one can help in this matter.
Thanks.
does your pc have com ports to connect your GPS.
Mine has 3 COM ports.
hassanmoussa   12-Nov-2018 20:12
onlinespiderman, GPS is not working
No way to add a GPS as their is no serial COM port available in the settings, navigation devices menu.
Do you have any idea how to add the GPS and also AIS
hassanmoussa   12-Nov-2018 20:15
onlinespiderman, yes i have a Garmin Bluetooth GPS. and when it is connected to the laptop it creates a serial com port, but in the menu of the navigation devices i can not find any com port to chose to add my GPS.
Fishbone_13   07-Jan-2019 21:00
captsakis,
Dkart 9000 I tried to install it in win 10 pro but the setup did not open in STEP №4,any proposal?
οκ,το εκανα,ολα καλα, I did it
I have the same problem. Any body can help me???
crazy_angle59   18-Feb-2019 11:22
first of all thanks
my problem is when i start dkart setup as administrator nothing happens ( the setup didnt start at all ) how can i fix this
windows 7 64
pahenti2008-87   20-Feb-2019 09:16
у меня не получается открыть архив,выдаёт ошибку, неправильный пароль или повреждение файла
Kucherkevich   26-Feb-2019 16:57
Ребята кто-нибудь на Windows 7 это ставил? Как отключить подпись драйверов на W7?Спасибо
naftis70   23-Mar-2019 11:22
First of all thank you for share onlinespiderman.For GPS connection you must know which com port gps is connected.
Go to MyComputer,right click,manage,device manager,ports.Example COM port 4.Double click,Port Settings and configure the Bits per second or(Baud Rate) to 4800.
Open dkart,co to SetUp,Conf,Navigation Devices,Main Positioning System...scroll and click AUTO.This open configuration window(GPS Device Settings).
Set Mode Customize,choose Comm Port,Example COM port 4,Device ID(Any) and Messages(RMC).
Now go to Communications,you will see the choosen port,Settings,Serial port 4 settings,set Baud Rate to 4800(leave the others as it is)Apply and OK.
Apply also to Settings window OK,and here it is.
Hope that helps,have a nice trips!!! Может по пиву?
P.S:dkart installed on WINDOWS 7(without SP1)without any problem.Also do this steps for the other Devices.For AIS i use an RTL DVBT dongle with PNAIS and Franson GpsGate Software.
bxhunter   02-Apr-2019 07:22
Also from my side thx for the sharing of dkart navigator!! Previously I used Telchart and been already happy with it, but dkart is an completely different level and to be honest way better than any transas distributions...
My only dearest wish would be a user manual in English, the only found was until now a Russian one.
litlone   17-Jun-2019 14:50
Спасибо огромное!... Гуд! Круто!!! Круто Ага
Всё отлично работает! только вот не понял абракадабру с паролем на лицензию. методом тыка подобрал на пару месяцев.
подскажите как менять цифры правильно что до конца 2019 года сделать лицензию, заранее благодарен.
и вопрос порт от гирокомпаса на как настроить? какое значение у него должно быть, АИС и GPS работают без проблем.
gidro988   25-Sep-2019 06:39
Подскажите, как подгрузить карты в формате S-57 (*.000). Или как их конвертировать в dKart Chart Format (*.dcf). Спасибо заранее.
neksu   01-Nov-2019 15:54
I have one does not fit the password to the archive? gives an error when unpacking the archive or damaged or the password is incorrect.
у меня у одного не подходит пароль к архиву? выдает ошибку при распаковке архива или поврежден или пароль не верный.
Arcan   01-Nov-2019 16:19
neksu, пароль на архив написан в первом посте. И еще, используйте последнюю версию WinRar, тогда все получится.
Marcuz   01-Nov-2019 18:19
naftis70, Do you have any link for PNAis coz am also using rtl sdr, i tried it with AisMon i seems running still it cant detect any target yet coz am not near at sea yet. Can you provide for the download thanks in advance.
-4
neksu   11-Nov-2019 15:44
Arcan, добрый вечер,подскажи где можно скачать дкарт 9000,эту ссылку так и не получилось распаковать...исть ли другие источники где можно скачать с инструкцией установки для хр,буду очень благодарен.
ни где не могу найти где можно было бы скачать кроме этого сайта
Arcan   11-Nov-2019 18:26
neksu, Я знаю что здесь - точно можно взять. Почитайте о торрентах здесь.
Посмотрите видео о том как скачивать торренты там же.
Лучше чем эта сборка - я не встречал.
The time now is: Today 18:06
