Seva2012   18-May-2018 13:29
MaxSeaTimeZero 2_1_2 хорошо что скачал раньше теперь вообще не найти в просторах инета. Забыл куда ложить ucpool у себя не нашел c:\ProgramData\TimeZero\MetaCatalog\ у меня c:\ProgramData\TimeZero\Dump только есть. пробую создать папку и туда кинуть файл. Есть у кого новые Maxsea codes все выше устаревшие и сильно! Заранее благодарен и еще нашел у китайцев сылку на торент MaxSeaTimeZero 2_1_2 скачаю гляну что там если норма позже скину ссылку если разрешат!
Polo75   11-Jul-2018 12:21
Hello,
I would like to download Maxsea Time Zero v3. Where can i find it please ?
Thanks for answer
Laurent
3
h5-n1   21-Aug-2018 12:15
Hi is there any chance that i get mapkey or UC key for this two maps: 1: SDVJEMM076MAP16.dbv 2: SDV33P02VMAP07.dbv ? Thank you in advance.
Guest   21-Aug-2018 19:38
44034Hi is there any chance that i get mapkey or UC key for this two maps: 1: SDVJEMM076MAP16.dbv 2: SDV33P02VMAP07.dbv ? Thank you in advance.
SDVJEMM076MAP16 50CC EF4C 0485 4322 00AC
Guest   22-Aug-2018 10:11
Guest, Thank you but unfortunately it does not work. It wont install the map. Can you please check again? Best regards.
h5-n1   22-Aug-2018 10:33
Guest, Sorry i wasn't logged on this was my post "Thank you but unfortunately it does not work. It wont install the map. Can you please check again? Best regards."
Arcan   22-Aug-2018 10:39
To All, who would like to get UC keys:
Click Me
1. Go to THIS site and register.
2. Find topic "Request for UC codes"
3. Post your request. Do not forget to precise your version of TZ ( 2.12 or 3.0; NAV or Pro)
4. If key exist and is known - in a few time you will get it.
Arcan   22-Aug-2018 10:51
h5-n1, BTW:
ClickMe
SDVJEMM076MAP16 - (v3.x) UC 50CCEF4C0485432212D8 - (v.2.x) UC 8F8256A4CF977F941290
SDV33P02VMAP07.dbv - All = Pro V3 UC 0777EAD43592A5CC04D7, NavV3 UC 8F09E92A2D791B7204CE, ProV2.1 UC 49AB7C208DBCBB3D04B1
h5-n1   22-Aug-2018 11:15
Arcan, Hi my version of software is MaxSea TimeZero Plot 2.0.1 (build 2.7126.0) I tried all codes that you provided and non of them works for me. Thank you veri much for your time.Or maybe i am doing something wrong, i put map files in "C:\Users\H5-N1\Documents\My MaxSea\Downloaded Charts" or should i put them directly in "C:\ProgramData\MaxSea Int\DATA\S57"
Arcan   22-Aug-2018 11:50
h5-n1, I suugest you need to reinstall TZ version either 2.1.2 or 3.0, otherwise you will get more and more problems with charts, as they will be reissued with new keys which are unknown and nobody will spend time to obtain keys for old version.
h5-n1   22-Aug-2018 12:25
I would very much like to install 3.0 or even 3.3 but i can't find them to download anywhere. I manage to install 3.3 but i don`t have serial key.
The time now is: Today 14:27
