Arcan   03-Mar-2018 13:12
During installation, whenever you will be asked : Standalone product or Connected to MFD - select Connected to MFD and type Gateway host/IP: 127.0.0.1
Further actions strictly as per instruction.
(Added to section "How to")
Arcan   09-Mar-2018 07:52
demofrommars, Well, if you have OS other than XP, this program probably will ask you to install .net components and for this reason will ask to connect with internet. Let it go and install these .net components from internet.
Arcan   09-Mar-2018 08:09
39513Where should i put the license? Do i have to copy to copy the whole folder or only the two files?
Read carefully "How To" in the first post and follow stricktly instructions:
"2. Two files from the folder Licensed- to copy in a folder with the replacement where you installed NAVI-PLANER."
nastey   09-Mar-2018 14:33
I didnt understand where to put licence.......also no2 ...of how to.....I didn't understand ......can anyone help me please..................
the   09-Mar-2018 17:04
все установил, но
сентинел протекшн просто устанавливается, не предлагает что-то менять
В итоге имею такой результат. Connection to pure server failed. далее пытаюсь подключиться к 127.0.0.1, пишет снова что фейлд.
жму кэнсл, пишет this program requires a dongle to run
Как с этим справиться?
Arcan   09-Mar-2018 17:47
nastey,
2. Two files from the folder Licensed - copy in a folder, where you installed NAVI-PLANER, with the replacement of original. Usually it is C:/Transas/PS4000 folder.
3. Install sentinel protection, then install emulator for win64 (Install.bat from administrator rights) or run emulator for win32 (sentemu).
Arcan   09-Mar-2018 17:48
the, Читай выше. Забыл поставить эмулятор, поэтому программа и "возмущается".
kav-des   09-Mar-2018 21:25
Arcan, Добрый вечер. У меня такая же проблема как у the, уже 2 раза переставлял.
Arcan   09-Mar-2018 22:23
kav-des, ну так если такая же проблема - нахрена переставлять то? установите эмулятор и дело с концом.
kav-des   10-Mar-2018 10:47
Arcan, 2 раза переставлял по инструкции, эмулятор установлен. К сожалению не работает. Попробовал установить на windows xp, там эмулятор не запускается( для 32) и та же проблема.
Arcan   10-Mar-2018 10:51
kav-des, Какая версия винды? Как вы узнали, что эмулятор установлен?
kav-des   10-Mar-2018 11:34
Arcan, Windows 7 home premium Service Pack 1, 64 bit. При установке эмулятора появляется черное окно установки, потом идет установка драйвера и написано что драйвер установлен.
kav-des   10-Mar-2018 12:03
Arcan, так точно добавлен. Не знаю что именно помогло, по несколько раз удалил загрузил, перезагрузил комп. Наконец то заработало. Спасибо большое!
Arcan   10-Mar-2018 12:43
kav-des, подкорректировал в который уже раз гуглёво-транслейтнутое описалово установки...
kav-des   10-Mar-2018 13:42
Arcan, не могу проложить маршрут автоматически( Auto route). Нажимаю и никакой реакции. В мануале написано что должно появиться окошко порт отхода и порт захода.
The time now is: Today 19:51
