faraon0012mail.ru   15-Dec-2020 11:58
Hi everybody!
Please assist...
Something went wrong and after couple of days of use the MaxSea TZ Pro 3.3 it start to show "CRACK" tiles instead of chart and doesn't get connection. I realize that program was banned during internet session.
How could it be solved? Any advices?
Many thanks in advance.
zhangskwcl   04-Jan-2021 01:17
faraon0012mail.ru, 1. setting up and cracking the TZ strictly following the procedure according to the post by westella of this theme; 2. for your case, as my experience, you'd better to reinstall your computer system to get a clean setting up enviroment because TZ has connected the internet and set up the crack determination program in your computer system. 3. a. during setting up, ban the internet; b. ban the TZ from firewall rules which is allowed in defaulut; c. the program itsself has another option to get internet connecttion under OPTION-INITIAL SETTINGS-CONNECTING TO INTERNET, it must be desabled too. The most important thing is to setup the app following westella's post.
Guest   04-Jan-2021 16:28
faraon0012mail.ru,
echo C:\Users\...\AppData\Local\Temp !!!
echo C:\Users\...\AppData\Roaming\Temp
echo C:\Users\...\Documents\Temp
echo C:\ProgramData\CrypKey
echo C:\ProgramData\Temp
ve všech adresářích vytvořit tyto složky
mkdir -p {4d36e96c-e325-11ce-bfc1-08002be10319}
mkdir -p {5e3e96c-e325-11ce-bfc1-08002be10319}
mkdir -p {6f3e96c64-64f325-12ce-bhc1-08102bf10318}
mkdir -p {8f3e21c64-63f325-12ce-z5g1-081999f10318}
mkdir -p {aaa3e21c64-63sdf25-1654e-zg1-0856410318}
Mohou zde být soubory se stejným názvem. Ty zmazat.
vitiru   08-Jan-2021 13:58
hi, i am now registered. I am trying to download maxsea timezero with keygen but i am not good with computers and i dont find the way to install it, Anybody can help me please? i will be very gratefull if somebody can help me to have this program running.
Guest   20-Jan-2021 16:16
доброго времени суток
Помогите найти UC коды для TZ PRO v4 для карт SDVJEMM111MAP20 dbv
SDVJEMM112MAP21 dbv
JONIKUSOV   07-Apr-2021 22:09
Здравствуйте,помогите пожалуйста,нужен UC для SDVJRSM002MAP18.dbv,зарание очень благодарен TZ 3 Pro
ЭРН   31-Jan-2022 14:05
Очень нужен UC для SDVJAFM210MAP20.DBV
Заранее благодарю за помощь.
Guest   07-Sep-2022 08:04
Всем доброго дня не могу зайти на gps форум.
Очень нужны коды на карты timezero3
SDVJENM299NMAP23
SDVJEWM226MAP24
SDVJEWM227MAP24
lednikoviy   07-Sep-2022 08:41
somen, Всем доброго дня не могу зайти на gps форум.
Буду благодарен за коды на карты timezero3 pro
SDVJENM299NMAP23
SDVJEWM226MAP24
SDVJEWM227MAP24
The time now is: Today 12:35
